Clutch recommendations? (Stock N/A)
Old Dec 4, 2021 | 03:23 PM
Shekel's Avatar
Question Clutch recommendations? (Stock N/A)
It's time my friends, I need a new clutch. Anybody have good recommendations? It's a stock N/A base model so I'm guessing I can put just about anything in there but considering it's my first time buying a clutch I figured I'd ask here first.
As a side note, is there any good preventative maintenance I can do while the trans is out? Thanks.
Old Dec 4, 2021 | 07:34 PM
with the tranny out you can inspect the rear main seal (or replace it), you can inspect the flywheel / get it resurfaced (check for any missing teeth that will annoy the starter), replace the throw out bearing, replace the clutch slave cylinder (I assume it has a hydraulic clutch). I assume you'll be replacing both the clutch disc and pressure plate. Shop at a Volvo friendly site like IPD USA or FCP Euro to see what after market/OEM parts they list. I'd probably go with an OEM brand like Sachs.
riley615
Mar 13, 2020 03:57 PM
frknvgn
2001-2013 model year V70
Sep 23, 2015 09:41 AM
joey 100
May 6, 2010 01:53 PM
timwu12
Mar 30, 2010 01:29 PM
D_Jack
Dec 3, 2008 09:24 PM
