collapsed battery :(
hi guys
I'm hoping someone can help me I had a collapsed battery on my 06 reg s40 1.6d which was causing the car to go haywire, I've replaced the battery and now the electrics come on as usual but the engine wont turn over. The car initially turned over and started but now nothing.......... can anyone help me please as to what the issue maybe.
You need fuel, spark, air, and correct timing for the engine to run. I'd start with the easy (and free) stuff first. Check fuel pressure. The newer 2004.5 and up models regulate fuel pressure via voltage supplied to the pump (not the old school regulator like the 1.9L engine). The fuel pressure sensor tells the fuel pump how much pressure to supply. Electrical problems could have fried either the sensor or the pump.
Then check for spark. I'd pull a coil and plug then check for spark while someone cranks the engine.
With the plugs removed I'd check for compression with a compression tester. This will tell you if the timing belt is correct as this is an interference engine. You can also remove the timing belt cover and give the belt a good look over.
Last is air. Just open the filter box and check the air filter for debris.
Do you have a check engine light? Any stored trouble codes?
kelsodatrini
05-28-2013 05:59 PM
