Door Handle getting more difficult to open
Old Aug 6, 2015 | 08:30 AM
MemphisSlimbo's Avatar
Default Door Handle getting more difficult to open
Hi All
Driver's side door handle on my daughter's 2005 S40 seems to take more force than seems like should be necessary to open. Kind of has a "notchy" feel to it.
Is there a lubrication point that might help or is this the sign of something else on its way out or already broken?
Thanks in advance!
Old Aug 6, 2015 | 10:10 AM
pierremcalpine's Avatar
I had the same problem with our 2010 V70 (I think it's the same handle design). I took some lubricant and sprayed it right into the outside handle itself (at both contact points) AND took some silicon grease and lubed the catch itself (where the door latches to the frame). That seemed to fix our issue.
Old Aug 6, 2015 | 10:29 AM
Default !
Thanks very much for the suggestions- certainly sounds like a good starting point!
Old Aug 10, 2015 | 10:59 AM
Default This seemed like it has helped
This seemed like it has helped- thanks!!
karutunian
Mar 27, 2021 05:44 PM
manoduv
Oct 24, 2013 12:22 PM
TMac
Apr 23, 2009 09:21 AM
andrewlittell
Dec 10, 2007 07:39 PM
