Front-end rattle?
Old Jul 13, 2012 | 08:27 PM
VA2GXB's Avatar
Default Front-end rattle?
Hi Guys,
My S40 has a knocking (not a rattle - I'd call droplinks a rattle) coming from the driver's (Left) side front suspension area. I've replaced the droplinks and control arms, but I'm beginning to think it might be the anti-roll/sway bar bushing. It clunks over bumps and when I rock the steering wheel. Nothing on either opposite lock, so not CV joints.
Steering is sharp as a tack, so it's not the rack going south....
I feel awfully idiotic for not checking the bushings when I was under there last week!
Liam
Old Jul 13, 2012 | 08:38 PM
Hudini's Avatar
Check the anti-roll bar where it bolts down under the rubber/aluminum bushing just as it goes under the body. You may be able to see it without removing the front wheel by turning the wheel all the way right. On mine the aluminum part broke allowing the anti-roll bar to lift and fall over bumps causing the knocking sound. Eventually both sides broke. And with big hands it's a PITA to get to the one 10mm bolt.
Old Jul 13, 2012 | 08:40 PM
VA2GXB's Avatar
Hudini,
Thanks! I'll be going on the lift again on Sunday morning, so I'll be sure to have a gander. It's not the topmount, not the arms... . At least it'll've had a quasi front-end rebuild!
Old Jul 13, 2012 | 08:45 PM
Hudini's Avatar
Lol, ok. The strut mount and bushing is also a known failure point. Mine sounded like something loose behind the glove box inside the dash. The noise was up high though, not like the anti-roll bar bushing where the noise was down by my feet.
Old Jul 13, 2012 | 08:47 PM
VA2GXB's Avatar
Hudini,
I'm feeling it through my feet when braking, so I'm guessing it's more toward the lower end?
Old Jul 13, 2012 | 08:54 PM
Hudini's Avatar
That would be my guess. Something down low. You also have 2 motor mounts down low on the center metal bar (the bar with the skid pad on it). Mine only made the car vibrate more not any clunking sounds IIRC.
Alan A. Armstrong
Sep 1, 2014 02:47 PM
Wing0
Dec 13, 2013 02:39 PM
pooky85
Jan 31, 2012 02:09 PM
04XC90T6AWD
Aug 1, 2011 02:23 PM
fhanselmann
Apr 23, 2008 01:48 PM
