Fuel gauge problem
Old Aug 25, 2021 | 01:10 PM
Adz's Avatar
Adz
Default Fuel gauge problem
Hi. My fuel gauge randomly drops even when the tank is full, then the engine starts to judder like its going to cut out.
mechanic changed fuel sender unit today but its still the same.
any one have any ideas what ot could be?
thanks.
Old Aug 25, 2021 | 02:24 PM
my hunch is your fuel pump is intermittantly losing power and that's impacting the sending unit as well. I'm not sure if the pump and sending unit share the same power source so try a quick test - turn the key on and see if the fuel gauge moves. Repeat with the fuel pump relay removed. If your guage doesnt work with the fuel pump relay in place, then it points to a voltage issue and may the relay, pump or wiring. Note that if the problem is solved with a new relay, you may betting an early warning that your pump is drawing too much current (which is what damages the relay) and is about to fail.
pfranco1
Jul 25, 2011 06:58 PM
Willow132
Feb 17, 2010 09:10 AM
dlaughlin
Jan 16, 2010 12:40 AM
Lichty17
Nov 9, 2005 06:59 PM
