Hard breaks while cold.
Old Jun 25, 2014 | 10:26 AM
bryants40's Avatar
Exclamation Hard breaks while cold.
Issue, when car is started and is cold the breaks are very hard even worst in reverse.
I recently replaced the old break fluid thinking it was the issue of the hard breaks while my vehicle warms up, it did not.
Any ideas?
I am assuming the break booster attached the the firewall, but have never worked on one before. Or maybe it is something else?
Thanks ahead of time.
Old Jun 25, 2014 | 04:10 PM
Hudini's Avatar
Check the electric brake pump. When the engine is first started and you step on the brake pedal you should hear a pump kick on. I believe its job is to pull vacuum when engine vacuum is low due to this being a turbo car. (assuming 2000-2004 1.9L S40?)
Old Jun 26, 2014 | 09:45 AM
bryants40's Avatar
It is a 2001.
Ah… Is it a vacuum pump under the fuse box on the driver side?
I noticed a blown fuse, replaced it, and the fuse blew again. I went to a pull-yard and got another unit. I would hear it turn on for roughly a week before it did the same thing. Possibly electrical, or…?
The breaks operate fine once they are warm, but I do not want it to turn into a bigger issue.
Old Jun 26, 2014 | 02:55 PM
oragex's Avatar
Do you know what grease was used for the sliding pins? Could be the grease gets 'hard' in cold weather. It takes silicone (synthetic) grease.
Old Jun 26, 2014 | 08:49 PM
pierremcalpine's Avatar
I had the same issue and it got to be very unsafe the colder it got. Once the car warmed up all was fine. Turned out that two vacuum hoses needed to be replaced. I caved and asked the dealership to fix. If you need the part numbers let me know.
Old Jun 26, 2014 | 10:18 PM
migbro's Avatar
No, "hard" grease is not the problem. lol
Old Jun 27, 2014 | 08:48 AM
bryants40's Avatar
What?
Old Jun 27, 2014 | 08:50 AM
bryants40's Avatar
Yes, anything will help. Were they easy to replace?
Old Jun 27, 2014 | 09:21 AM
oragex's Avatar
Originally Posted by bryants40
What?
Some lubricants will seize in low temperatures, preventing the caliper pins to slide properly.
Old Jun 28, 2014 | 11:00 AM
Here are the two parts that were replaced for my issue. Haven't had a problem since:
30620958 Hose
Stop light switch 9128577-5
Old Jun 29, 2014 | 09:32 PM
bryants40's Avatar
30620958 Hose
Does the stop light switch just affect the lights?
I was having a hard time finding the hose with that number, do you recall what it looked like?
Old Jun 30, 2014 | 07:53 AM
Here's a link to the part. As for the stop light swith I honestly don't remember the details of why that part was required.
30620958. Volvo. Hose.
Old Jul 1, 2014 | 01:20 AM
migbro's Avatar
Ahahahaha. I think you really believe that. lol
Aeisner
Feb 16, 2007 10:17 PM
colgate41
May 23, 2006 09:31 PM
colgate41
Mar 14, 2006 01:01 AM
colgate41
Dec 16, 2005 08:54 PM
colgate41
Aug 15, 2005 12:45 AM
