HELP! What's this? It's making noise...
Old Jun 20, 2010 | 07:40 PM
rashidgaladanci's Avatar
Default HELP! What's this? It's making noise...
Hi all,
So when I turn of my s40, this thing (circled in red in the picture) continues to make an unhealthy sounding winding down noise for awhile and then stops. Is it related to the fan?....should I replace? Expensive?
Thanks all!
Old Jun 21, 2010 | 11:24 AM
SVTfocusO3's Avatar
It is related to the brakes, an aux. pump.
does it run continously? it should run when you hit the brakes, even with engine off. pos 2.
let me know if it runs continuously.
Old Jun 21, 2010 | 07:30 PM
First of all, thanks for the quick response, much appreciated. Unfortunately the car is in NY right now and I'm in DC but basically I got in the car, pressed on the brake and turned the car on. Then I decided to look under the hood (not for any particular reason, sound etc just to look under the hood). I turned the car off, popped the hood and heard that thing winding down in a smooth manner, not on and off. After maybe 20-30 seconds the sound came to a stop....perhaps that's normal? I guess it just surprised me because I thought that only the fan would be winding down (it was silent, I guess because I had only just turned the car on)
Thanks again
Old Jun 22, 2010 | 02:34 PM
SVTfocusO3's Avatar
It probably is normal, but if it has a problem, it will set a check engine light because it will burn up running too long. keep an eye out, there is a switch, in the hose connected to it behind the battery that fails. In the pic., the hose is to the left of the master cylinder.
dannyseager
May 4, 2021 09:13 AM
Lawbrum319
Jun 24, 2006 10:30 PM
floryed
Sep 1, 2005 08:47 PM
rantiddlybobo
Apr 11, 2004 12:47 PM
