How to change time on '03 S40?
Old Nov 19, 2007 | 09:42 PM
degoxin's Avatar
Default How to change time on '03 S40?
Greetings.
I recently replaced the battery of my '03 S40. Now, everything is fine but the clock is showing wrong time. I was trying to correctit, but just couldn't find how to adjust the time. It was not mentioned in the factory manual. Can any one help me out?
Thanks a lot!
Old Nov 19, 2007 | 10:12 PM
Andy's Avatar
Default RE: How to change time on '03 S40?
If it's the same as my '02, I think you just turn the same button that you push to reset the trip meter.
Old Nov 20, 2007 | 07:39 AM
degoxin's Avatar
Andy,
Thanks for your replay.
I've tried that way. But that button is firmly fixed, I can only push it but not turn.
Can anyone give another solution or confirm that the botton on my car is broken?
Old Nov 20, 2007 | 11:10 AM
Andy's Avatar
Not sure if this link to Volvo will work, but the owner's manual is online.
http://new.volvocars.com/ownersdocs/.../03sv40_00.htm
from p. 20 :
6 Button for setting clock/resetting trip odometer
In both cases, the ignition must be switched on
Clock: Without pressing the button, turn it clockwise to advance the clock, or counterclockwise to set the clock back.
Trip odometer: Press the button to reset the trip odometer.
Old Nov 21, 2007 | 04:22 PM
parmbrust's Avatar
I have an 03 S40 and was able to turn mine. It doesn't feel like it turns but it does. Just turn (takes a little pressure) and hold it, the clock will change.
Old Nov 21, 2007 | 09:12 PM
jks2's Avatar
Ditto. Same as my 02 S60.
Old Nov 28, 2015 | 05:39 AM
RonCarl's Avatar
Tried but only the minutes adjust. How do I switch from the minutes to the hour. I want to adjust the hours.
Old Nov 28, 2015 | 06:50 AM
pierremcalpine's Avatar
It is one and the same. Just hold the dial to one side and eventually the minutes will fastforward and the hour will change.
Old Nov 28, 2015 | 07:04 AM
RonCarl's Avatar
Thanx pierremcalpine. It has just worked!
Old Feb 15, 2022 | 01:24 AM
Jarno Voermans's Avatar
Originally Posted by degoxin
Andy,
it may feel like it's fixed but you can turn it a really tiny bit and that is enough to change the clock
Kenaisteve
Mar 3, 2010 03:53 PM
RRTEC
Dec 27, 2008 08:54 AM
degoxin
Nov 20, 2007 11:43 AM
Veronica
Feb 1, 2007 08:50 PM
Uhills
Apr 5, 2005 08:22 PM
