Installed speedometer cluster but lost info center
Old Aug 8, 2019 | 07:12 PM
Eric Hites's Avatar
Default Installed speedometer cluster but lost info center
Upon install of the speedometer it seems to work ok so far however there is no info center showing. The info center lets you look at temp, current MPG, MPG since reset, miles til empty. Could this be a different model speedometer or does the DIM need reset at Volvo?
Old Aug 9, 2019 | 11:12 AM
habbyguy's Avatar
Was it the same part number (or at least year / model)? The other thing would be to check the fuse that supplies power to the display module, as it wouldn't be hard to short something out during the R/R of the module.
Old Aug 9, 2019 | 04:13 PM
Eric Hites's Avatar
Thank you
The look is exactly the same but the tech had it so fast I didn't get to compare numbers. The display works showing time and temp but it is nor changeable to mpg, miles to empty, etc. Hitting the reset on the control does nothing. That' why I thought, maybe it needs to be programmed by Volvo.
Old Aug 9, 2019 | 06:06 PM
habbyguy's Avatar
Not sure about the vintage of your car (you never mentioned it...) but on the 2005 to 2009 S40s, the "advanced features" on the cluster are a dealer-programmed option. I can easily believe that's the problem (which is radically different than the one you described originally).
Old Aug 9, 2019 | 07:04 PM
Eric Hites's Avatar
2004 S40 1.9T base.
Thanks, I'll call the dealer and see what the options are.
Old Aug 13, 2019 | 03:22 PM
Eric Hites's Avatar
Default Volvo Buffalo NY no longer works on 06 or later cars
Or so they told me today.
Old Aug 14, 2019 | 11:53 AM
habbyguy's Avatar
That's sad... OTOH, Volvo stealerships tendency to make service difficult and expensive is what makes used Volvos such a smokin' buy for DIY wrench-twisters like me... it scares everyone away from them ;-)
Old Aug 19, 2019 | 03:49 PM
Youdoofus's Avatar
how bad was it to get the gauge binnacle out? I have to adjust a speedo needle on mine
Atlantis
Apr 29, 2016 12:06 PM
sly_fox
May 8, 2011 01:40 AM
kvolvot5
Oct 28, 2010 01:04 PM
kvolvot5
Oct 25, 2010 05:19 AM
Mr Yuck
Sep 3, 2006 05:56 PM
