Leaking in passenger floor board
Old Oct 13, 2021 | 01:56 AM
LukeCurrey7's Avatar
Default Leaking in passenger floor board
My Volvo s40 only leaks water when it rains so I know it’s not the A/C. The tray were the windshield wipers sit. When it’s full of pine needles the water doesn’t come through as much. Whenever there’s nothing and the car is clean it’s a puddle in the floorboard.
Old Oct 13, 2021 | 09:32 AM
Do you have a sunroof?
What year car?
Old Oct 14, 2021 | 12:38 AM
What year car?
yes I do have a sunroof but I think it’s the drain up by the hood that might be clogged.
Old Oct 14, 2021 | 09:47 PM
dogface03's Avatar
The was a so called "Silent Recall" on the sun roof drain port clogging. I just had to get the CEM replaced on my daughter's car due to water damage.
Old Oct 15, 2021 | 11:51 AM
habbyguy's Avatar
Easy enough to check the sunroof drain(s). Just open the sunroof, and pour a quart of water in on the outside (drainage side) of the channel, on both sides. If it runs right out, you know the drains are working. If it doesn't (or if your carpet gets wetter) you have your answer, too...
Old Oct 24, 2021 | 05:55 PM
BrianS40's Avatar
Sunroof drain tubes clogged or disconnected. These run along each side of the windscreen behind the trim. There is a youtube video that shows how to fix it. Not sure if that is your issue but it is common.
ed schuler
1998-2000 model year V70
Aug 4, 2011 06:56 AM
john knox
Jul 31, 2010 12:54 PM
Bill Parecki
Dec 14, 2008 09:16 PM
stefalfonso19
Jul 22, 2008 03:02 PM
97GLT
Nov 1, 2007 07:03 PM
