Led low beam warning light
Old Apr 10, 2018 | 08:00 AM
Vackers40's Avatar
Default Led low beam warning light
Has anyone else had trouble with the warning light after installing leds? Have ordered resistors with h11 adapters maybe that will fix problem. Warning light doesn't come on with daytime running lights just when headlights are turned on.
Old Apr 10, 2018 | 11:55 AM
Corey Conklin's Avatar
Fault-tracing information
Condition
No diagnostic trouble codes (DTCs) stored in the central electronic module (CEM).
Substitute value
None
Possible source
Defective fuse
Defective bulb or Xenon lamp
Open-circuit in one of the power supplies, one of the cables from the lighting switch, one of the cables to the low beam or one of the ground cables from the bulbs
Short-circuit to ground in one of the power supply cables or one of the cables for the low beam
Defective fog lamp switch
Contact resistance and oxidation.
Fault symptom[s]
Low beam does not work.
Old Apr 11, 2018 | 07:50 AM
Hudini's Avatar
I had the same issue after ordering CEM "compatible" LED headlights. The flickering associated with "non-compliant" LEDs was gone but that warning message replaced it. Since it's my wife's car I had to go back to standard halogen. No solution yet for me either.
Volvo_Neps
1998-2000 model year V70
Sep 12, 2024 06:53 AM
Turbogirl7
Feb 6, 2024 06:37 AM
Atelaroli
Apr 24, 2018 12:20 PM
breknraj
2001-2013 model year XC70
Nov 16, 2016 09:34 AM
volvo40_2k
Jul 28, 2009 09:18 PM
