New to Volvo idle surging.
Old Oct 13, 2014 | 09:22 AM
metalriff's Avatar
Default New to Volvo idle surging.
New to this brand of car, 2000 s40, I really like it. Running like crap, changed the plugs and coils/wires. runs great now except the idle surges terribly , 1000 rpm to 2500 , where should I start? Thanks Todd
Old Oct 13, 2014 | 11:14 AM
utapesgeometriam's Avatar
I'd check vacuum lines. There isn't much that will cause that sort of behavior, and vacuum lines are at the top of the list.
There are a number of vacuum lines that run from the throttle body area. If it looks like there's a line connected to each of them I'd remove them one by one and plug them with my finger and see if the surging goes away. (Warning: Be careful when removing as you can cause the aged vacuum lines to start leaking... even if they aren't already...) The line that when capped at the throttle body causes the surging to stop is the one that is leaking. Replace as necessary.
Old Oct 13, 2014 | 05:14 PM
Hudini's Avatar
Idle Air Control motor dirty or defective. MAF needs cleaning. Just guesses.
Old Oct 13, 2014 | 07:58 PM
damien360's Avatar
Of its turbo's check the hose from the intercooler to the intake. That's known to break
Old Oct 14, 2014 | 05:37 AM
metalriff's Avatar
Thanks for the tips I will let you know what I find.
Old Oct 16, 2014 | 01:08 PM
metalriff's Avatar
I checked for any vacuum leaks with carb spray, nothing found. I removed the idle air control valve , soaked it with carb cleaner then lubed it up, cleaned the connections on the 2 wire plug put it back on and it runs perfect, no more surging. I don't know whether it was mechanical ,cleaning it or electrical since the plug was really corroded but it runs as it should now. 5 minute fix. Thanks.
Old Oct 20, 2014 | 08:55 AM
metalriff's Avatar
I thought I had this fixed but it started surging again. I removed the idle air controller again and soaked it for a few hours and it ran fine again for a hour or so and started acting up again. So at least I narrowed it down to that part. Next I got some gasket material and made a new gasket with just the bolt holes essentially blocking it off. Reinstalled the iac left it plugged in,turned up the idle manually and it runs great. No issues hot or cold start idles about 7~800 nice and smooth. Thanks.
Old Oct 20, 2014 | 10:49 AM
Disco2's Avatar
I went thru about 3 IAC units when i had mine. Finally occurred to me on the third one what the problem was...it said "Ford" on the part.
palebeachbum
Sep 28, 2010 05:50 PM
Tarheel Taxi
Nov 11, 2009 08:01 PM
outdoor7or24
Sep 17, 2008 09:26 AM
worldspeaker
Dec 23, 2006 02:07 AM
Richard74
Jul 22, 2006 12:39 AM
