No heat----- help
Old Nov 26, 2010 | 07:27 PM
Greenmudshark's Avatar
Default No heat----- help
I have a problem with the climate control module in mym S_40 w/ 130,000 miles.. How do you change it??? Thanks Mud
Old Nov 26, 2010 | 10:49 PM
AutoNaut's Avatar
What year?
Old Nov 27, 2010 | 02:12 PM
2001 S-40 130,000 miles
Old Dec 2, 2010 | 12:51 PM
Counselor828's Avatar
Are you sure the climate control module needs changing? On a trip to Canada last winter with my 2000 S40, my thermostat stuck open (very cold day), and all the way back from Canada I had no heat (pretty cold in the car but I made it home no problem). Engine temp showed very low during the trip but car is fine. However, had no heat for that trip. Is your car getting to operating temp normally? If not, then there may not be enough residual heat in your car to have heat blown into your cabin by your heating system. I changed my themostat and all was fine after that. Just an idea.
Old Dec 3, 2010 | 08:16 PM
Yea-- That's what I thought also.. But I changed the thermo when I had the timing belt done.. Still No heat...Now it works when it wants to.. Not consistent .. On/off thing...
Gmac1321
Oct 10, 2010 11:37 AM
Greenmudshark
Dec 23, 2009 07:33 AM
jpm2346
Oct 2, 2009 10:22 AM
98c70turbo
Apr 22, 2008 07:33 AM
revriff
Mar 10, 2008 07:35 PM
