no oil pressure
Old Oct 2, 2014 | 03:21 PM
bugyengines's Avatar
Unhappy no oil pressure
hello everyone i'm new here, just built volvo s40 2004 t5, it fired up well but no oil pressure present, already installed gauge to check pressure but negative, im afraid oil pump was not well installed, any input or advice what to do before removing oil pump, car has been just fired up a couple of times for few seconds to not damage engine, thank you in advance.
Old Oct 3, 2014 | 04:13 AM
Hudini's Avatar
There is an old trick of filling the pump with Vaseline jelly to prime it.
I have no clue if you can prime it like the pushrod engines through the distributor hole.
Is this a new pump?
Old Oct 3, 2014 | 11:03 AM
Is this a new pump?
i did that trick with pump, it is not new but was checked and seemed to be fine..
Old Oct 3, 2014 | 07:50 PM
Hudini's Avatar
I had a neighbor whose old 240 broke the timing belt. No problem, it's a non-interference engine. On closer inspection I discovered the cam was seized due to lack of oil pressure. Upon tearing down the oil pump you could see marks on the housing from the over-pressure spring. The over-pressure valve would hang open on a cold start. My neighbor had unplugged the oil pressure warning light because it was ON all the time and it bothered him! (Moral? He needed a new oil pump)
Old Oct 3, 2014 | 10:59 PM
Vida's Avatar
Are you sure you checked the oil pickup tube screen real well? You're going to have to pull the oil pan down and recheck your work. Good luck.
Old Oct 4, 2014 | 12:48 PM
well, i'm really sure oil pickup was enough tight to not lose pressure, about hudini said it may be pump because i checked for grooves or scratches on it but never looked for over-pressure spring that well, mmmmm i'm gonna remove pump and report back what i see on it.
Old Oct 9, 2014 | 10:06 AM
i'm glad to post there is oil pressure now, removed pan and oil pickup and found there were some bolts missed where there is oil pressure... what oil should i use?
Old Oct 9, 2014 | 09:47 PM
Hudini's Avatar
Full synthetic, any brand, weight depending on location. Mine are in Tennessee so 5W-30 works well. Down in Miami or further south maybe a 10W-30 or 10W-40. Up north maybe 0W-30. The temp ranges are printed in the Owners Manual. For me the most important item is full synthetic.
bydand
2001-2013 model year XC70
47
Aug 4, 2025 04:52 PM
nuclearseal
Aug 17, 2022 01:48 PM
brettboze
Mar 26, 2012 06:25 PM
Jack
Jul 1, 2008 06:15 PM
