no start
Old Jan 9, 2015 | 06:48 AM
cable5's Avatar
Default no start
HI have a 2001 s40 change cam sensor crank sensor coils has fuel pres 50psi good comp. good spark clear codes started ones ran great turn key now will not start turns over has fuel and spark thanks cable 5
Old Jan 9, 2015 | 06:52 AM
Hudini's Avatar
Try holding the gas pedal down a little while you crank the engine. I've seen a bad Idle Air Control motor cause issues like these.
Old Jan 13, 2015 | 09:39 PM
syked's Avatar
What about the MAF..could be faulty.
Are you sure the fuel pump engages when you turn the key to the red position? the fuel pressure could be residual.
DecalService
Dec 4, 2019 10:52 PM
MMAFIGHTER
Sep 2, 2008 08:43 PM
WagHag
Dec 2, 2007 08:45 AM
auser
Nov 20, 2004 10:27 AM
