Oil Light After Adding Oil
Old Aug 17, 2015 | 10:35 AM
tallen's Avatar
Default Oil Light After Adding Oil
Been browsing a while now but first post. My 2001 burns oil so I have to add about .5 qts every month or so. Added it yesterday, as I normally check fluids on Sundays and when I woke up this morning the oil light was on. Checked the oil level and that's perfect. Drove around the block a few times to see if I'm leaking or spraying oil anywhere and I can't see anything. The engine is perfectly clean.
What am I missing? Noob to the forum and my first Volvo as well
Old Aug 17, 2015 | 11:20 AM
migbro's Avatar
The oil light is not an oil level warning it's an oil pressure warning.
If you're driving around with the oil light on you're making a potentially expensive bet that the problem is a faulty oil pressure sender and not an actual low oil pressure problem.
Old Aug 17, 2015 | 12:01 PM
tallen's Avatar
Thanks for the quick reply.
I will not be driving it today then, lol. It just turned on this morning. Hoping that the couples of blocks I drove it didn't kill it or cause major damage.
First things first. I guess I'll be changing the oil today.
I just searched and found several reasons for this. How
Old Aug 18, 2015 | 02:38 PM
Hopefully its just the pressure sending unit - but to be sure don't drive until you can put a pressure gauge on it and drop in a new sending unit. If you can't find a pressure gauge you can try replacing the sensor first then crank to see if it goes out. If the light remains on, time to pull the oil pan and inspect for debris in the pick up and pan. Just had this done to my 2012 VW CC with 48K miles for an intermittant oil light. After replacing the sensor and measuring oil pressure at various temps and engine load they got the light to come on... Turns out there was debris in the pick up and VW dropped in a new $9500 long block and turbo under warranty... Hopefully your's is way simpler than that!
dcm0123
Jan 31, 2010 06:54 PM
grochef
Apr 30, 2006 12:59 PM
Tony_S70_99
Jan 21, 2006 05:29 PM
Tony_S70_99
Jul 21, 2005 11:13 PM
altshoe
Mar 21, 2005 01:51 PM
