PCV clogged. Fixable
Old May 21, 2014 | 10:20 AM
nealeas's Avatar
Default PCV clogged. Fixable
Hey,
just took my car into get the timing belt replaced and the mechanic told me that I have oil leaking in my engine and that my pccv system is clogged. He recommends replacing it but I was wondering if it could just as easily be unclogged and work fine. Also, wondering if the oil leaks were a related problem? tell me what you think.
Old May 21, 2014 | 02:57 PM
oragex's Avatar
In some cases the box and hoses can be cleaned but need to came out. also the PCV system goes inside the oil pan and it can also be clogged down there - the oil pan must be removed. the oil leak can be due to PCV system being clogged and raising the pressure inside the oil pan. It's a common issue.
grndslm
Apr 14, 2013 05:03 PM
SonsofThunder
Dec 8, 2012 10:20 AM
joker834
May 15, 2010 07:47 PM
lancezos
Apr 12, 2010 08:11 PM
Bob Loblaw
Oct 8, 2009 05:58 PM
