s80 electrical problem after battery replacement
Old May 5, 2006 | 12:22 AM
billp46's Avatar
Default s80 electrical problem after battery replacement
We replaced a dying battery. We have all power except to the panel below the radio/cd(radio ok). There is no heater/AC or fan control...all dead. nothing on that lower panel works. We've checked all fuses and no help. We checked the main bus where there is 60 amp fuses and all ok... Any ideas................
******************We tried the reset with the key on and replaced battery with no help***********
********We had the dealer look at the climate unit and says it needs to be replaced and reprogrammed for $1100. So buyer beware this is a possibility if you replace a dead battery. Anyone else with any help before we subcum to Volvo's short comings.......
Old May 5, 2006 | 05:08 PM
jerryman's Avatar
Default RE: s80 electrical problem after battery replacement
tech has a reply to this on this forum. Disconnect batt, connect cables (+) (-) together for 5 minutes. Turn ignition on, reconnect battery.
Old May 5, 2006 | 09:13 PM
If that doesn't work try locking and unlocking the car with the key or Remote.
Leej
Mar 15, 2021 08:28 PM
I8ASaleen
May 7, 2019 05:37 PM
JohnJoseph
Jan 18, 2012 08:11 PM
Tango
Jul 14, 2009 10:35 AM
cmercon
Feb 2, 2009 02:15 AM
