R/R fuel rail on 2000 s40
Old May 31, 2017 | 05:47 PM
Hammer's Avatar
Default R/R fuel rail on 2000 s40
Need to remove fuel rail to swap out the MAP sensor. Do I have to pull the fuel fuse and start the engine to remove fuel prior?
Any help appreciated. Grazie!
Old May 31, 2017 | 10:28 PM
Hudini's Avatar
Normally you pull the fuse then run the engine until the fuel pressure is depleted. You can also use the shrader valve to relieve pressure but this tends to be messy with raw fuel spilling onto your engine.
Old Jun 1, 2017 | 01:38 PM
pierremcalpine's Avatar
as I recall (maybe stating the obvious) the order is turn car on, then pull fuse, then wait until the car stalls. Try to start again (just to be sure). Then, keeping fuse out, proceed with planned work.
FYI: I had a devil of a time trying to get new injector rubber rings back in when I changed my PCV. I finally gave up and put it all back together with the original rubber rings which I thankfully had not thrown out. I think my problem was that I used after market rubber rings - go VOLVO on those if this is part of your planned work.
chachouu
Apr 30, 2015 10:47 AM
kkzdad
Mar 19, 2012 12:48 AM
MHUSTON
Dec 13, 2007 06:45 PM
S70driver
Mar 26, 2007 05:50 PM
edahlgren
Oct 7, 2005 09:53 PM
