Replaced headlight assembly - low beam not working
Old Jan 8, 2022 | 05:11 PM
jck823's Avatar
Default Replaced headlight assembly - low beam not working
Hello,
2007 Volvo S40
I replaced the passenger headlight assembly and the low beam light is not working. All other lights in the assembly are working - high beam, turn signal, day light. The fuses seem good - maybe I checked the wrong fuse.
What could be the problem?
Thank you.
Old Jan 8, 2022 | 06:51 PM
Power at bulb with your $5 test light? Swap bulbs?
Old Jan 10, 2022 | 07:46 AM
richardkonrad's Avatar
Is it Xenon or normal halogen , either way check power first
Old Jan 15, 2022 | 10:05 AM
jck823's Avatar
Default Check power
How and where do you check the power for left low beam? It is new light assembly and all other lights are working.
Is it possible for only the low beam to stop working on the connector to the assembly or in the CEM?
It is normal halogen light.
Old Jan 15, 2022 | 10:53 AM
Check power at the connector to the bulb with your $4 test light from harbor freight - https://www.harborfreight.com/612v-c...ead-63603.html
PeterVolvo
Feb 15, 2020 03:24 PM
enjuaguese
Jan 1, 2016 04:13 PM
willingrvw
Jul 18, 2015 06:14 PM
Fred P
Mar 19, 2013 03:59 PM
darnshepp
Jul 6, 2011 08:50 AM
