S40 2.4L petrol ‘05 where is the fuel filter located? (UK)
Old Dec 31, 2018 | 05:53 AM
dirtychinchilla's Avatar
Default S40 2.4L petrol ‘05 where is the fuel filter located? (UK)
Hi guys,
I’m new here. Just hoping someone might be able to advise me where the fuel filter on my S40 is located. Ok I’m the UK for reference, and it’s an S40 2.4L petrol ‘05 model.
I’ve had a good look under the car and for the life of me can’t find it! The car currently has a fault, which I believe is “fuel pressure sensor” and I’m trying to fix it myself. Thought I’d try the cheapest fuel part first...
Thanks in in advance for your help,
dirtychinchilla
Old Jan 1, 2019 | 04:33 PM
Hudini's Avatar
It's underneath the car back by the tank area on my 2005. I would think yours is near the same area. If you cannot see it clearly it might be hiding behind a plastic cover.
Probably not going to fix a fuel pressure sensor problem though. Tell us how it goes?
Old Jan 2, 2019 | 01:00 AM
Morning, thanks for that. Which side is it on? I spent ages looking on the driver side and couldn’t find anything!
It probably won’t the pressure sensor issue, but I think for £8 it’s worth trying. Not sure what I’ll try next to be honest.
Old Jan 2, 2019 | 11:41 AM
Should be easy enough to find the cannister - its about 3 inches around, 4-5 inches long. Also check Youtube for vids / google for pics. +1 on Hudini noting the filter is not likely to cause the fault code. I'd start by looking in front of the rear wheels / under rear right passenger seat area..
As to the likely cause, here's a vid on how to replace the fuel pressure sensor
Old Jan 28, 2019 | 06:01 AM
https://www.youtube.com/watch?v=zZkBeSE9kwE
Hi there, thanks very much for this. I couldn't find the fuel filter so took it back and forgot about it.
However, I changed the fuel pressure sensor on Saturday - super easy - and the fault has now gone, which is wonderful. So thank you very much once again.
Old Jan 28, 2019 | 04:36 PM
just to note, not all newer Volvos have a fuel filter. the cannister is pretty generic - 4 inches long, 3 inches round with the fuel lines running in and out of the ends - usually in the back in front of the rear wheels. If you don't see it, no worries, you may not even have one :-)
Old Jan 29, 2019 | 01:43 AM
Yup I couldn't find it at all!! I did some research beforehand and was convinced I knew where it was, but half an hour of searching later I still couldn't find it. And, of course, managed to fix it by replacing the sensor
Joe2004.5s40
Feb 22, 2016 03:09 AM
yzmotoguy
Sep 17, 2014 05:11 AM
tommo
Mar 16, 2010 12:13 PM
yzmotoguy
Apr 21, 2006 09:17 PM
flyingcurtains
Feb 11, 2006 05:47 PM
