S40 brake problems
Old Aug 9, 2014 | 01:12 PM
Hughelrick's Avatar
Default S40 brake problems
Hi, I have just bought a 51 reg s40 1.9. The problem is the brakes. When you try to stop it sometimes puts the ABS on even when there is no need for it to come on. Also, it needs more force on the brake to stop than the v40 I had. When I checked the callipers they were a bit sticky on the slide bolts but they were cleaned and were fine after that.
Cheers in advance!
Old Aug 15, 2014 | 07:33 PM
BlackRain's Avatar
oooooooohhh ......
i have the same problem ..i can't persuade the mechanic that its happened
can you put images for the part you had cleaned
and thank you
Counselor828
May 18, 2009 09:58 PM
MaZoN
Aug 5, 2008 06:52 PM
thullz
Nov 7, 2006 09:25 AM
mywifescar
Jan 13, 2006 12:59 PM
