S40 cv joints bad?
Old Sep 2, 2013 | 08:49 AM
obx338's Avatar
Default S40 cv joints bad?
Here is what the car is doing. When it is cold there is a bad noise and it sounds like it is coming from the right side wheel when turning but I would not call it a click, it also has a thud when going over a bump. This morning when driving it cold the noise happen so I was at a stop turned the wheel to the right while holding the brakes gave it gas and the noise was very bad. I have had it on jack stands and felt all normal places to look, the strut nut is still in the center position. Could this be bad CV joints? The car has 170000 miles? Thank you
Old Sep 2, 2013 | 09:03 AM
ValleyB's Avatar
When you turn one direction it only makes the noise? If so that's wheel bearing/hub.
Old Sep 2, 2013 | 10:30 AM
obx338's Avatar
It is either direction maybe a little worse to the right. I did lift it up and i have a small amount of play on the inboard CV joint up and down.
ANDYB2005S40
Jan 15, 2016 11:12 AM
77091
Jun 7, 2015 01:58 AM
obx338
Sep 2, 2013 08:48 AM
rene
Mar 6, 2008 06:44 PM
