S40 LED lighting upgrade help
Old Jun 24, 2013 | 05:51 PM
2003S40's Avatar
Default S40 LED lighting upgrade help
So I've recently purchased some LED bulbs to replace my brake, indicator, and reverse lights on my 2003 S40. However I've ran into many problems.
When I installed the brake lights, both the "bulb out" and "DSA" indicator lights came up on the dashboard. When I installed the indicator lights, I ran into a hyperflashing issue that I thought could be solved by buying 3ohm 50W resistors to wire into the circuit. However this didn't fix the problem either. So now I'm stuck and I feel like I've wasted a lot of money on these bulbs. I'm wondering if anybody has successfully installed LED lights without any issues and what they had to do to make it work? Thanks
Old Jun 24, 2013 | 05:57 PM
Hudini's Avatar
Also post your question over on Swedespeed Forums as there seems to be more modders active there.
Old Jun 25, 2013 | 09:06 PM
difflock54's Avatar
Try removing the bulbs and refitting them again the opposite way round (180 degrees)
This is what you do with the LED's for the interior dash lighting.
Seems they are polarity sensitive but dont blow if put in the wrong way accidently.
Old Jul 5, 2013 | 04:13 PM
Jay Dawn's Avatar
I bought, meassured and found the after marker trailer adapters to make incandescent fail sensored cars work with LED lit trailers use 100 ohm resistors for the running and turn signal circuits. they go across the Led to make the circuit draw more current...not in series with the Led.
Old Jul 10, 2013 | 09:33 PM
Athilla's Avatar
I also just tried to upgrade the brake light pair on my '01 S40 to LEDs and got the same issue with the "bulb out" and "DSA" indicator lights (why DSA would fail beats me). Once the incandescent bulbs were put back, all was well again. Asides from adding resistors, would anything else work? I have not tried reversing the bulbs yet...
Thanks!
Old Jul 11, 2013 | 08:08 AM
Hudini's Avatar
If you can add the resistor and make a write up I bet many people would be appreciative. Seems LEDs are the future.
Old Jul 11, 2013 | 07:03 PM
Athilla's Avatar
Any idea what resistance and where/how to connect it to the socket and/or bulb? I'm not really an electrical guru
Old Jul 12, 2013 | 08:52 AM
2003S40's Avatar
Thanks!
Last week my uncle showed me a wiring diagram for the DSA system in the S40 and it revealed that the brake lights were somehow tied into the circuit for the DSA, which explains why that light comes on if the bulbs are out. Seems like a cheap shortcut that Volvo took. I wish I could find the diagram but unfortunately it was on one of those sites like alldatadiy and I don't have a subscription.
What I'm thinking about doing is buying some 1156 bulb sockets, like these 2XLED Bulb Socket Extension Replacement Holder Wire Harness 1156 1141 BA15S 7506 | eBay , and adding them into the circuit with the regular incandescent installed, then just tucking the bulbs out of sight somewhere. That way the power draw will be almost exactly the same and should (hopefully?) stop the hyperflashing issue. The only problem I can think of is the LED's not being as bright but only time will tell. I'll post an update as soon as I do it. I'm in the middle of doing a radio replacement job at the moment.
Old Jul 12, 2013 | 01:52 PM
Athilla's Avatar
In terms of luminosity for the brake lights (asides from the burn-out and DSA issue) , these LEDs were just about the same as the stock incandescent bulbs... 2X 54 LED 1156 BA15S R5W 5630 SMD Auto Tail Turn Single Light Bulb DC 12V White | eBay
Old Jul 13, 2013 | 10:06 AM
Jay Dawn's Avatar
Read my ealier post above.....try a 100 ohm power resistor wired across the bulb and not in series with the bulb.
Old Jul 13, 2013 | 06:23 PM
difflock54's Avatar
Try this link for the wiring diagrams you may be needing to assist you.
Comprehensive list of models included so just search thru for the S40. 2003.
Hope it helps you.
Volvo Wiring Diagrams
Wouldn't adding additional incandescent bulbs (however hidden) into the circuit along with the LED's result in very little gain as the incandescent bulbs will still require changing more frequently as per standard and overall the loads on the circuit would be higher than previous?
As soon as one of those bulbs blows the warning lights would also reappear.
Old Jul 20, 2013 | 01:54 PM
2003S40's Avatar
Hope it helps you.
I'm aware of this but I mainly care about how they look and plus I already have the bulbs so might as well put them to use somehow
hockeyfool
2001-2013 model year V70
Feb 25, 2014 10:55 PM
dragonslair
Oct 23, 2011 02:15 PM
redbottle
Jun 28, 2010 09:13 PM
jgc
Nov 11, 2009 07:19 PM
jbnery6465
Feb 9, 2008 04:26 PM
