S40 Master Cyl Float Problem
Old Apr 15, 2013 | 09:34 AM
tszwieg's Avatar
Default S40 Master Cyl Float Problem
Guys, new to Volvo and this forum. Just purchased a 2000 S40 with 120k miles. Within the first 500 miles, I installed new rear calipers, pads and rotors. While bleading the brakes I ran the fluid low enough for the brake light to come on. I verified everything is hooked up correctly. What I found is that the fluid level float in the master cylinder slowly sinks to the bottom of the master cylinder thus causing the brake light to come on. Using a clean pin, I can get the float to rise back top the top and the brake light will go off, but it slowly sinks again. Any ideas out there?
Thanks
Old Apr 18, 2013 | 08:01 PM
Get a new cap.
Old Apr 19, 2013 | 02:32 AM
Hudini's Avatar
Sounds like the float has a leak (is it hollow?)? Is it dirty? No help here.
NFrank89
May 25, 2011 05:21 AM
devo
Jan 24, 2011 05:36 PM
J Dubb
Jul 16, 2010 02:38 AM
rgmendoza
Mar 13, 2009 08:39 PM
iamnickcarter
Sep 21, 2007 04:20 AM
