S40 Rear Brake Question
Old Sep 26, 2005 | 11:50 AM
rfred's Avatar
Default S40 Rear Brake Question
I understand that a special tool is required to retract the rear brake caliper piston. Can someone tell me if I rotate it clockwise or counter-clockwise? Is a lot of pressure while doing this required? I assume that once I'm finished that it needs to be rotated back. Also, can anyone tell me where to get this special tool. I bought one at Advance Auto Parts, but it didn't fit the Volvo. The one I got is basically a cube with different fittings on all sides for different manufacturers. Each side had a 3/8" square for a ratchet to plug into. Is this the type of tool that I am looking for?
Old Sep 30, 2005 | 01:42 AM
Jerryb's Avatar
Default RE: S40 Rear Brake Question
I have that same tool and one of the sides was a little too big so I filed down the little bumps so it fit in the face of the piston. You need to push the piston and turn clockwise to force the piston back into the caliper. When you put the pads back in the caliper and assemble everything, the piston will come out properly when you step on the brakes. Be patient and the piston will go back in.
Old Oct 1, 2005 | 02:56 PM
rfred's Avatar
OK, I filed the bumps and now they fit the piston. I am able to rotate it, but it's not retracting at all. I'm applying as much pressure as I can while I rotate, but no luck. Any suggestions?
Old Oct 2, 2005 | 12:17 AM
http://www.harborfreight.com/cpi/cta...emnumber=40732
This tool is awesome and usually goes on sale to about $20.00
Sometimes it takes major pressure.
I use a tool that pushes and turns at the same time.
PaddyG
1998-2000 model year V70
Feb 17, 2014 05:23 PM
agardin10
May 22, 2011 10:52 AM
GRHMB
Jun 21, 2007 07:19 AM
Sidney03
May 28, 2006 08:06 PM
T6Drivr
Feb 13, 2005 08:38 PM
