starting issues 2002 volvo s40!?!?
Old Jan 6, 2009 | 07:06 PM
rupert77's Avatar
Default starting issues 2002 volvo s40!?!?
Hi everyone,
Have just joined up as i have recently purchased a 2002 volvo s40 2L petrol. Love the car, looks great and is very comfortable. The problem is, is that i had issues regarding the car starting over the few months i've had it. At first the symptoms were like those in alot of posts that i have looked at ( starting fine when cold and then after a short trip would have to crank for longer to start , as if car was choking trying to start, not getting the right dosage of petrol if that makes sense). but then one day after not driving it for a day or two it wouldnt start atall even from cold. I could try for atleast 15/20 secs cranking but no joy. So i took it a mechanic who got it going and sais the problem was the fuel pump. So i understood this to be true as i knew my fuel gauge wasnt working so i thought the pump must be on it's way out too. So i decided to get a 2nd hand pump just incase it would go again and i could do the change myself. So eventually it has happened again ,so i replaced the pump and the gauge is now working but the car is still not starting. So i done a power check from the socket that connects to the pump and there is no power flow getting to it. I have checked all fuses in car and engine and all seem fine. Is there anything else it could be as i know that it cant be down to broken wiring as it was going before and broke and going again. Thanks, any ideas would be very welcome.
Old Jan 9, 2009 | 07:19 PM
jakery7's Avatar
Default RE: starting issues 2002 volvo s40!?!?
I had a similar problem with mine and it ended up being bad coils on the spark plugs. You might want to check that out.
Good luck!
Old Jan 11, 2009 | 10:46 AM
rupert77's Avatar
just got a diagnostics test done and the reading was, faulty cam shaft sensor, so i have to wait a couple of days till i get the new one. Will let you know what the outcome is ok.
Old Jan 13, 2009 | 11:43 AM
sek8031's Avatar
I'm having similar problems with an '02 S40, it's taking significantly more cranking to start than it used to. I didn't think it could be a fuel pump issue because once it starts it runs fine. Any suggestions?
Old Jan 13, 2009 | 01:29 PM
Check the fuel pressure regulator.
dcjcdc
Sep 4, 2014 11:26 PM
siddiq
Jul 20, 2011 07:11 PM
webeckers
Sep 14, 2008 05:03 AM
hocbj23
May 21, 2007 09:05 AM
