Sunroof Leak
There is a black trim that runs around the sunroof panel itself. Water is seeping in at the corner of the sunroof panel where this trim is supposed to be permanantly sealed. Can this trim be removed from the glass panel and replaced or do I have to buy the entire glass panel with the trim already attached at the factory ?
Water will occasionally drip into the cabin, usually after the car has been sitting in the rain and a small amount of water collects on top of the sunroof. The leak is not between the glass seal and the roof panel. The sunroof itself is leaking. The trim that is glued around the sunroof glass and moves with the sunroof. Water is coming in between the actual glass on the sunroof and this trim.
Never did find a solution. The dripping seems to have slowed down or stopped though . It is raining hard today, so I will check. I was going to try some kind of silicon / sealant if the drip gets worse....
