sunroof leak
Old Aug 12, 2009 | 09:29 AM
tom0317's Avatar
Default sunroof leak
My daughter’s ’92 240 sedan has a leaking sunroof. The sunroof is the crank type not the electric, any suggestions on what to do or how to fix short of just duck taping over the joints.
I would like for her to be able to use the sun roof after I stop the leak.
Old Aug 12, 2009 | 10:21 AM
fcpgroton's Avatar
Former Sponsor
The only reason I could think of that would cause the sunroof to leak would be if one of the drains are clogged. There is a drain in each corner of the sunroof. If you open the sunroof, you will be able to get to the front to to clean them out. The rear two, you would have to drop the headliner to get to. Try cleaning the front two out first and see if the leak stops.
nattyderek
Jun 14, 2010 01:16 PM
rspi
Feb 19, 2010 09:58 PM
ikes4ever
Nov 17, 2008 08:40 AM
volvokidkyle18
May 12, 2008 01:34 PM
Lichty17
Aug 29, 2005 09:48 PM
