Swap the Blow off valve?
Old Oct 1, 2005 | 01:00 AM
NFSS40's Avatar
Default Swap the Blow off valve?
Has anyone out there swapped the blow off valve in thier 2000-04 S40 for an aftermarket one? Is it possible? Will it help power? I want more power and / or the cool sound of the loud wooosh of the aftermarket ones.
Old Oct 1, 2005 | 01:25 AM
Default RE: Swap the Blow off valve?
You can install a cone filter with the kit from Eurosportuning and get the noise you wish.
Adding the blow off valve helps sometimes and other times makes it run worse.
Old Oct 7, 2005 | 04:55 AM
NFSS40's Avatar
Why would the cone filter give me the louder blow off sound? Does the BOV vent into the intake? Or does it vent into the atmosphere? If it vents back into the intake, then the intake system would be the obvious choice, because, albiet small, the power increase would be an added bonus. Thanks for the help, your input is appreciated.
Old Oct 7, 2005 | 11:15 PM
As far as I know it vents back into the intake.
Old Oct 8, 2005 | 02:53 AM
NFSS40's Avatar
Good to know, that will definitely be my next purchase. Thanks again.
Turbovolv85023
Jan 3, 2008 08:13 PM
JohnS4
Apr 7, 2007 12:33 PM
Tony_S70_99
Jan 21, 2006 05:29 PM
Tony_S70_99
Jul 21, 2005 11:13 PM
cecilvaliant
Jan 27, 2004 04:41 PM
