temperature sensor
Are you sure it's the coolant temp sensor that's the issue? On the 1.9L engines the thermostat going bad would give the bad temp sensor error code. A simple and cheap fix with the t-stat, not so much with the sensor.
On the 1.9L engine the CTS is on the t-stat housing. Anyone know the location on the 2.5L T5 engine?
atikovi
09-21-2006 08:26 PM
