Testing fuel pressure....Long cranking issue
Old Mar 4, 2014 | 10:17 AM
volvoaj's Avatar
Default Testing fuel pressure....Long cranking issue
So I am finally getting around to testing the fuel pressure because I still have the long cranking issue. I was told this my a member (Hudini) who has helped me GREATLY.
Hudini
"The long cranking has usually been a bad Fuel Pressure Regulator. Test fuel pressure for about 60 psi at key on and no instant drop to zero pressure when you turn the key off."
Is the fuel pressure suppose to be at 60 psi with its long crank? Because I read somewhere else on the volvo forums that it should be testing at 45 psi, so I just want to verify what it should be?
VolvoAl
Dec 6, 2014 07:10 PM
S40 in Fla
Nov 1, 2012 08:39 PM
theequalizer
Oct 20, 2012 08:57 PM
turbo940
Mar 29, 2008 07:18 PM
Natalie
Jan 14, 2006 11:53 PM
