Timing belt replacement issue
Old Feb 13, 2011 | 04:45 PM
skippermccoy's Avatar
Default Timing belt replacement issue
When replacing the belt i noticed the marks on the crank do not line up. I went to set it at TDC and the marks on the crank are to the right at about 3 oclock. Is the cylinder closest to the cam pulleys number 1 or 4. i checked it against both but same issue.
Old Feb 13, 2011 | 09:53 PM
#1 is closest to the timing belt.
So if you line up the cam marks the crank marks are off?
Old Feb 14, 2011 | 07:39 AM
Yep. It looks like the crank pulley was removed and put on wrong. I got the car for cheap from my neighbor that got a little impatient on waiting for me to help him replace the belt. He couldnt get the belt off so he cut it. When I line up the 3 marks on the crank pulley(2 witness marks and the line on the pulley mount) it is about mid stroke. When I put it to TDC its at 3 oclock. I am not sure on the year of the motor in the car. When I went to test fit the belt before the store closed it is about 3 inches to long. It is gates number t252 I tried 2 different belts the car is a 2000.
04v70
Jul 17, 2009 11:01 AM
bcon415
Sep 19, 2008 07:17 PM
Soloracer
Aug 26, 2006 04:43 PM
Qamar
Aug 24, 2005 07:37 PM
