turbo problems
Old Jan 4, 2006 | 10:30 AM
ZIGZAG's Avatar
Default turbo problems
I wanted to ask if anyone has had turbo problems. My current situation is when I open the turbo up it starts to hesitate and surge. This just started a couple of days ago. I thought it was water in the gas but I used some stuff and the car seems to run fine other then when I really push the turbo. Even mild use of the turbo cause a slight hesitation. Is my turbo going bad, can they do that, what else could cause this. I dont have a code reader and there is not a single light on the dash.
Old Jan 4, 2006 | 11:00 AM
S70driver's Avatar
Default RE: turbo problems
I don't know what the exact problem is.
However I can tell you turbos can go bad.
Old Jan 4, 2006 | 01:17 PM
ZIGZAG's Avatar
I was looking at some other posts and they mention coils. Would coils cause this sort of behavior?
Old Jan 4, 2006 | 02:04 PM
nandrolone's Avatar
Sounds like spark coils.
Old Jan 4, 2006 | 09:12 PM
Either a bad Coil/Coils or spark plugs will cause that problem.
Old Jan 5, 2006 | 10:36 AM
ZIGZAG's Avatar
Thanks for the info. I had to run it in last night for them to pull code. Wish I had my own code reader. I will keep everyone who is interested posted on what I find out.
Old Jan 5, 2006 | 01:56 PM
ZIGZAG's Avatar
UPDATE
pulled codes and tells me that it is missfiring. (great waste of 50 bucks i knew that)
Recommend change spark plugs.
Might be more to come.
Old Jan 5, 2006 | 04:23 PM
S70driver's Avatar
Coil packs, my dad had this problem on his 96 960 wagon.
Old Jan 5, 2006 | 04:46 PM
ZIGZAG's Avatar
UPDATE
Just to update on what needed to be done and for anyone else who is interested. They changed the plugs and tell me that fixed it. I am however a bit pissed, not because the whole thing cost me 350 bucks but I replaced the spark plugs about six months ago. Dealer tells me they are only good for about 40 000 kms. yikes what is with that.
I will post tommorrow on how the car actually is running. I hope they didn't flash my chip.
Old Jan 5, 2006 | 11:14 PM
headshok2002's Avatar
Turbo'd cars are hard on plugs... Lots of people start using copper plugs for like 3 dollars each... and just change them yourself every 20K miles or so, at a cost of a whopping 12 bucks
Old Jan 6, 2006 | 11:09 AM
ZIGZAG's Avatar
Now that I know about this problem I will be looking after the plugs myself. I would recommend that you dont use bosch platnium plugs. I had a look at the ones he pulled and the look pretty bad considering they were only in there for 6-8 months.
Old Jan 6, 2006 | 11:41 AM
Yeah I put denso iridiums in my audi about 3 months ago... have put about 4000 miles on them... I experienced a bit of misfire last week, on two seprate tanks of gas... hasn't happened since, but it definately happened. I don't know if the plugs are to blame... but I know I wont go blowing 10+ dollars per plug ever again... I'll be switching to copper and changing them frequently.
Old Jan 6, 2006 | 01:45 PM
ZIGZAG's Avatar
I am going to have to agree with you on that one. Spending more money on plugs is not really worth it if you have to change them every 30,000 kms.
Not wasting my time on platnuim or irdium or what ever. I will just buy OEM and change more often.
Old Jan 6, 2006 | 09:25 PM
How much are OEM though? My audi uses NGK double platinums or "laser platinums" which are like 15 a plug from the dealer (22 bucks CDN a plug anyways).
I will be using like 3-4 dollar NGK coppers.
Old Jan 16, 2006 | 09:37 PM
pmilian's Avatar
I have a 2001 S40 that had the exact problem. I had the coils and spark plugs wire change and the problem was solved. My mechanic told me that the coils go bad on this model often... I hope this helps
akabond
May 28, 2011 08:17 PM
AnEskimo
Sep 22, 2010 07:28 AM
1Gray760T
Nov 13, 2009 08:19 PM
jekelvin
Oct 5, 2006 11:36 PM
rl92821
Feb 1, 2004 12:54 PM
