Volvo S40 rattle past 2k rpm with AC on
Old Jul 26, 2022 | 04:43 AM
Djox12's Avatar
Default Volvo S40 rattle past 2k rpm with AC on
Greetings fellow forum members,
I have a 2005 Volvo S40 1.6D and I just noticed that when I rev it past 2k rpm, a rattling sound is heard from the right side of the vehicle. Being an old 4 cyl diesel it's pretty noisy after 2k rpm but this rattle definitely isn't normal engine noise. At first I thought the rattle is coming from some lose interior trim since the car is 17 years old but I had discovered that it only occurs when the AC is on. Turn the AC off, sounds normal, turn AC on and the rattle appears. I can't seem to replicate it by reving the engine while stationary, only while driving.
One more thing, I found that when the AC is on, the sound of the car becomes different, I know that the AC robs a lot of power from the engine and that the engine needs to work harder to keep it running but when the AC is on a thumping noise can be heard in addiotion to normal engine noise. Same thing, turn off AC the thumping goes away.
Any suggestions?
Thank you!
Old Jul 26, 2022 | 09:30 AM
Possible causes for an AC rattle: failing compressor, worn bearings in serpentine belt pulleys/idlers, worn serpentine belt, worn compressor clutch (ie bearings again) - on some cars the clutch can be replaced separately from the compressor...
Old Jul 27, 2022 | 11:21 AM
richardkonrad's Avatar
Yes at that age and only when AC is on must the AC compressor , when the AC is off the belt turns but the clutch on the compressor disconnects the AC compressor , so sounds like its the compressor when under load
daver80
Apr 30, 2012 08:20 AM
bocaboca
May 14, 2010 09:03 AM
Thundamentalist
Apr 10, 2010 09:54 PM
NoleWithAVolvo
May 15, 2007 06:25 PM
ClarkeRussell
Nov 22, 2005 12:42 AM
