Want more boost 00 V40 1.9 w/12T
Old Jun 21, 2012 | 10:05 PM
frtdrmrose7's Avatar
Default Want more boost 00 V40 1.9 w/12T
I have just completed stage 0 and want some more power, I have looked for the TD04-14T with no luck(even in the U.K, shipping issues). I have though come across a TD04HL-13T would this be an upgrade? Or can I get a MBC and raise the boost on the 12T and if so what would be the limit PSI on the 12T? Or if anyone has an advice on a turbo I could realistically find I would appreciate it. I am a turbo novice, for now at least. Thanks guys
Old Jun 28, 2012 | 07:38 AM
austinnoah1's Avatar
The 2000 volvo s40 can be upgraded to a 16T from a Dodge Neon TD04HL-16T turbo.
If your just wanting more power.... buy a CAI (Cold Air intake) and make sure you have no exhaust leaks, which i'm assuming you've already done.
For stage zero make sure you've :
Changed the spark plugs to NGK Iridium or Equal
Changed the spark plug wires
Checked the Water Pump and Serp. Belt
Only put 93 Octane in your engine.(it really does get you going faster)
The thing with upgrading the turbo is it will put stress on the stock light pressure turbo engine..
Get a manual boost controller and boost your turbo up to about 10-11 and get a cold air intake you will feel a major diffrence or a 3" Turbo Downpipe would really wake your car up.
Old Jun 2, 2013 | 08:28 PM
Beltran55's Avatar
Hello, sorry I'm really late but I was wondering if you did put a 14 T can you not do a ecu upgrade ? And how does that manual boos control work ? Won't the ecu still be confused ?
sessions124
Feb 27, 2025 11:10 AM
gilber33
Apr 30, 2014 07:23 PM
plog17
Oct 5, 2012 08:18 AM
endneu913
Mar 28, 2010 11:41 PM
gordon368
Jun 6, 2009 03:01 AM
