Weird noise?
Old Apr 22, 2019 | 03:35 PM
Cody Leon's Avatar
Default Weird noise?
Makes noise when I turn the wheel when car is on jacks. Also, when I’m driving and turn I get a bad tie rod end sounds but upon inspection the tie rods look to be fine
Old Apr 23, 2019 | 09:23 AM
turning wheels on jacks will likely create some brake pad noises - my experience its difficult to hear a bad wheel bearing on a wheel with no load. Not sure what a bad tie rod sounds like - I suspect the sound is other thump makers like spring seat, sway bar end links/bushings, control arms. Best to inspect all rubber bits in the suspension and do some push/pull to see if you have any deflection. Also check the steering rack mounts etc.
jeropon
Dec 19, 2013 11:48 PM
dlukowsk
Sep 27, 2011 10:24 AM
Sanel30
Feb 15, 2010 08:41 PM
tenchu
May 12, 2008 10:09 PM
knight rider
Jun 9, 2005 08:45 PM
