00 S80 Clunking Noise?
Old May 11, 2008 | 05:57 PM
tenchu's Avatar
Default 00 S80 Clunking Noise?
I got a clunking noise when I turn my wheel. But not all the time, it seems to be random. Today it didnt do it all day, but then I was driving thru the parking lot at the store and it was doing it over and over as i turned the wheel (from a small turn to a big turn, no matter what, clunking still). But then by the time I got home, it wasn't doing it anymore. I jacked one wheel up on my car (F/L) and it had a little play side to side (front to back) but not up and down, would this be tie rod? If so, is it just the end, or what? Is this something I can do in my garage with common tools (and an impact gun)
Old May 11, 2008 | 06:04 PM
air force rascal's Avatar
Default RE: 00 S80 Clunking Noise?
You may want to check your CV Joints...Good Luck and Happy motoring....
Old May 11, 2008 | 07:31 PM
tenchu's Avatar
The CVs dont look cracked or covered in grease, so I think they are good. But the front and rear end links are pretty f**ked on the boot area. The lower part of the front end links both are missing the boots all together! Anyone think it'd be this rather than the tie rods/ball joins? The steering also feels loose around turns and on bumpy roads.
Old May 11, 2008 | 09:00 PM
If you have side to side play the tie rod is bad.
Pull on the sway bar and feel for a clunk. If you feel it then it is bad.
Old May 11, 2008 | 09:02 PM
tenchu's Avatar
The inner and outter tie rod or what? And what way do i pull on the sway bar? to the front, back, or side?
Old May 11, 2008 | 09:03 PM
tenchu's Avatar
Oh, and if it does clunk, that means the sway bar is bad, or the end links?
Old May 12, 2008 | 05:29 PM
You have to look and see of the inner or outer tie rod is bad.
For the sway bar pull down towards the ground. If it does click or clank the end link is bad.
Old May 12, 2008 | 07:09 PM
tenchu's Avatar
How do you check a tie rod?
Old May 12, 2008 | 10:09 PM
You will have to have it jacked up again. Then either have someone watch or have someone more the tire from side to side and see where the play is that you said you felt.
Rasta
Feb 13, 2015 03:18 PM
leebae
Mar 26, 2008 06:59 PM
ice queen
Jan 16, 2008 02:58 PM
m1964
Feb 3, 2006 12:32 AM
Red XC
Suspension
Oct 22, 2005 11:58 AM
