What can be causing this?
Well, my "check engine" light came on, so I took it to Autozone to check the codes. Came back as "Cylinder 3 misfire". The guy said thatit looks like it's time for a tuneup. Does that sound about right at 77K miles? I bought spark plugs a few weeks back and was planning on installing them this weekend. I'm now wondering if that will fix the problem.
Well, I successfully changed my spark plugs this weekend. That seemed to havefix my idling problem.
However, my check engine light is still on.
Should that have gone away if that fixed my cylinder 3 misfire? Or is there a chance that the 2 problemswere unrelated?
![Smile](https://volvoforums.com/forum/images/smilies/smile.gif)
![Frown](https://volvoforums.com/forum/images/smilies/frown.gif)
There could be 2 possible causes with this one. 1st have the fuel pressure regulator checked this could cause the problem and is common. 2nd could be the VVT solenoid and or the unit, this will cause misfire DTCs. Spark plugs are easy, but they IMO are not the problem alone.
ludeless
03-14-2006 11:27 PM
