rear fog light question, unused socket causing problems
Old Nov 25, 2007 | 08:26 PM
team's Avatar
Default rear fog light question, unused socket causing problems
Ok, i have found my bulb position error problem, it is the unused rear fog light (passenger side). I took it out and put a bulb in the unused socket and the buld position error went away. Now I know that there is not supposed to be a fog light bulb in the passenger side (and it also wont fit in lense)but what goes in the empty socket to keep the failure light from turning on?
Old Nov 26, 2007 | 12:58 PM
Default RE: rear fog light question, unused socket causing problems
They aren't attached to the bulb failure system. When you took the bulb assembly out you might have made one of the burned bulbs work again.
I would inspect all elements really good. If you see them burnt replace the bulb.
Old Nov 26, 2007 | 09:28 PM
team's Avatar
I ended up drilling out the blank hole for the passenger rear fog light and putting a bulb in it and the light went out. Oh well, if it works i wont complain.
apoulos
Apr 15, 2022 05:08 PM
92Sedan
May 13, 2015 09:44 PM
Stevenpat
Nov 23, 2013 11:20 AM
chef
Feb 2, 2011 01:47 PM
jaymangano
Aug 17, 2010 05:10 PM
