Whistling sound
Old Oct 14, 2009 | 01:12 PM
  #21
StnThree's Avatar
Well that's the thing I'm NOT out of warranty. I bought the car as a demo an as part of that I got the 100k mile extended warranty. I have 90k on the car. They keep telling me about how rare this happens and so on. Than why on earth would they not cover it?
Yup it's time to call Volvo!!
Old Oct 14, 2009 | 02:08 PM
  #22
StnThree's Avatar
Hey guys I just noticed the C30 they are parting out on the for sale page that turbo would work for me right? I should see what they want for it huh?
Old Oct 14, 2009 | 03:00 PM
  #23
Somthngfrce's Avatar
Well, someone doesn't want to pay for it, but it sure is a good looking car,lol. Dude,sounds like someone is blowing smoke you know where. Just call Corpo and tell them the deal and you will furnish paperwork with the warranty! I bet 5 bucks they will slap that dealer straight into fixing it!
Old Oct 14, 2009 | 10:30 PM
  #24
AutoNaut's Avatar
As far as I know the C30 turbo should be the same.
Old Oct 19, 2009 | 10:20 AM
  #25
StnThree's Avatar
I am getting no place with Volvo they're backing the dealer.
Old Oct 25, 2009 | 08:25 AM
  #26
sVolvo60's Avatar
Hi Sorry if I hi-jack your thread, don't mean to... I am trying to determine if the "whistling" sound I am hearing recently is the same thing you are hearing.
I have a '04 s60 2.5t, and when I am running between 60-70 mph, I am hearing what sounds like someone blowing across the top of beer bottle. It's was originally intermittent, with no noticeable correlation to other conditions, but now it's more frequent, and will start when off throttle at speed above, but will increasing in volume when stepping on the throttle, once I get past ~70-75, it will usually go away.
Can you describe what you were hearing? Anyone else have any thoughts?
Please let me know if I should move to another thread.
Thanks!
Mike
Old Oct 25, 2009 | 05:58 PM
  #27
So what now??
Old Oct 26, 2009 | 12:34 PM
  #28
StnThree's Avatar
That my friend is the $2,000.00 question! I'm not sure... I have called a couple places that I have been referred to. But that is as far as I have gotten. I'm open to suggestions!
Old Oct 26, 2009 | 05:07 PM
  #29
Man, that's a steep price tag! Do u know what turbo u are running? Maybe get one from Garrett and have someone drop it in. I am sure there is a HUGE markup in your parts and labor.
Old Nov 5, 2009 | 10:03 AM
  #30
StnThree's Avatar
Alright so here is the latest. The car is currently at an independent Volvo specialist... The good news is that he thinks the turbo is fine. he said that the PCV hose is cracked in half and something about the pcv housing (sorry can't remember exactly what he said) or that it could be a bad waste gate, maybe water pump. All better than turbo problems!! I believe this because I still feel and hear the turbo working.
On a side note how can Volvo just say... Yep it's a bad turbo!! Thank you very much that will be $2000.00.
Old May 9, 2014 | 10:47 AM
  #31
SoK66's Avatar
Resurrecting this oldie. How was this resolved? My GF's V40 is a high miler and has this whistling racket. Unrelated, so far I've replaced all the motor mounts, the timing belt set & VVT gear, found a torn hose from the intercooler to the idle air valve and done it's scheduled major maintenance. The whistle sounds to me like it's boost related, but I can't find the source. Knowing the resolution on this would really help.. THX!
Old May 9, 2014 | 12:40 PM
  #32
Hudini's Avatar
The whistling sound has usually been a clogged PCV system. Does the sound change when you remove the oil dipstick?
Old May 10, 2014 | 08:31 AM
  #33
StnThree's Avatar
Wow haven't been on here in a long time. What the problem ended up being was the turbo/manifold gasket was shot. We replaced that an all was good.
Good luck!
Old May 10, 2014 | 10:06 AM
  #34
SoK66's Avatar
Haven't tried that, I'll give it a go and report. This is my GF's V40. Service records indcate the PCV trap, etc. was replaced about 25k miles ago.
Old May 10, 2014 | 10:09 AM
  #35
SoK66's Avatar
Good luck!
Thanks! By manifold do you mean the intake manifold? The whistling does appear to be turbo pressure related, rises & falls as one accelerates, etc. I found a completely torn idle air hose and was sure that was the source of the whistling noise,. The hose goes from the top of the intercooler to the idle air valve port, but turned out not the issue.
Old May 10, 2014 | 02:07 PM
  #36
StnThree's Avatar
No the gasket between the block an the exhaust manifold. It was a medal gasket like 8 bucks at the dealer.
Old May 12, 2014 | 06:11 PM
  #37
StnThree's Avatar
Old May 13, 2014 | 08:33 AM
  #38
SoK66's Avatar
I tried removing the dipstick and driving it. The whistling didn't change, so we'l assume the PCV system a repaired as the service history claims and is OK. I'll look into the exhaust manifold gaskets.
Intuitively it seems like the noise would be on the presure side of the turbo.
sVolvo60
Jul 21, 2010 12:56 AM
nmh
Jul 15, 2010 05:18 PM
craig1104
Feb 3, 2010 01:02 PM
filip
May 31, 2008 05:20 AM
frontsight
Apr 16, 2006 04:35 AM
