02 S60 Heater blows cold???
Old Dec 31, 2015 | 04:18 AM
trosey103's Avatar
Default 02 S60 Heater blows cold???
I have a 02 s60 with MCC, and it blows cool luke warm air at best with heat ***** turned all the way up. It seems to be a little warmer if you turn it to the top on the windshield. The temp ***** seems to get colder when you turn them down, and warmer when you turn them up but not hot at all.
I flushed radiator, and heater core very good, both hoses get hot, replaced thermostat.
Is there a way to recalibrate the heat control?
Old Dec 31, 2015 | 05:29 PM
pkrface's Avatar
Does one side blow a different temp than the other?
Check the blend door solenoids to make sure it is moving based on adjusting the temp. Pretty common issue in auto climate control systems.
laur9400
Jan 21, 2011 11:16 PM
fastoldcarz
Aug 9, 2010 06:19 PM
Ghost Brick
Jul 10, 2010 05:54 PM
cdavisonswim
May 4, 2010 08:41 PM
Royalty
Aug 31, 2009 09:56 PM
