02 T5 Steering Rack
Old Dec 10, 2007 | 03:03 PM
snowman84664's Avatar
Default 02 T5 Steering Rack
I need to replace the steering rack on my 2002 S60 T5 and was wondering if anyone has does this and can give me some tips on the procedure. I'm trying to decide whether or not i can do it in my garage or if i should try and find a lift to do it under. Any help would be appreciated.
Old Dec 10, 2007 | 06:00 PM
Default RE: 02 T5 Steering Rack
You will need to support the engine while you drop the rear of the subframe.
Old Dec 12, 2007 | 07:20 PM
Thanks Tech. Now I'm stuck trying to figure out whether or not I have variable assist or not. Any easy way to check? I don't see any wires going into the rack but I'm not 100% sure. Any obvious signs I should look for?
Old Dec 12, 2007 | 07:23 PM
If you had it the wires would be visible from the top near where the steering shaft attaches to the top of the rack.
No wires means you don't have it.
Old Dec 12, 2007 | 07:31 PM
Sounds good. I'll double check before ordering the rack. Thanks.
timmins
Sep 28, 2022 02:00 PM
maduko
Nov 21, 2011 09:03 PM
redbriq
May 5, 2011 10:40 PM
intence
Mar 3, 2008 08:40 PM
katiejoyful
Dec 12, 2007 04:49 PM
