05' S60 2.5T wobble/vibration problems
Old 01-05-2014 | 11:31 PM
SouthernSwap's Avatar
Default 05' S60 2.5T wobble/vibration problems
I have an 05' S60 2.5T FWD(?) I bought over the weekend and upon testing its speed limits, I was unable to complete the test because of a severe wobble past 60~75 MPH. All of the tires are the same type (BF Goodrich Touring) and all are at 32psi. Could it be that the tires are too skinny for that rate of speed? or is it that theres something wrong with an axle? I really would like to know asap.
Thanks
Old 01-06-2014 | 12:02 AM
damien360's Avatar
Do you feel any vibration before that speed?
Old 01-06-2014 | 12:20 AM
only sound. id have to test it again, but it sounds like what my explorer did, kind of like if one of the tires was not aligned all the way and wobbling back and forth but i couldnt see it
but to answer your question no
Old 01-07-2014 | 08:11 PM
oragex's Avatar
If tires don't have bubbles and are balanced, it might be a loose suspension bolt or a loose/worn axle shaft (check axle center bolt as well)..
Old 01-08-2014 | 10:37 PM
It was both of the rear tires. They became scalloped and needed replacing. I did the cheap route and picked up 2 tires on the cheap, but soon ill be grabbing some of these:
Riken Raptor - 215/55R16 STDW BW - All Season Tire - Automotive - Tires & Wheels - Tires - Car Tires
are they worth it?
threedukes
07-03-2013 07:24 PM
mdebarro
04-05-2010 05:36 PM
2k5s40MN
04-19-2008 10:45 AM
ocean238
04-17-2008 07:20 PM
WagHag
01-02-2007 10:09 PM
