2001 s60 t5 tire rub
Old May 3, 2011 | 09:29 AM
coefamily's Avatar
Default 2001 s60 t5 tire rub
Hi guys,
new to this forum, but I have a problem that stumps me;
my stock size tires rub against the inside of the wheel well (frame) when turnning hard, causing a wear line in my tires, cause poor balance and ultimatly needing new tires. Tire guys cant figure out why this is.
Any answers?
Old May 3, 2011 | 10:43 AM
jda2000's Avatar
what size tires do you have?
Maybe you need thicker steering stops to prevent the rubbing.
Old May 3, 2011 | 12:20 PM
tgkoenigsegg106's Avatar
Another solution in addition to steering stops are wheel spacers that can push your wheels out more.
Old May 5, 2011 | 09:00 AM
ryanideus's Avatar
I have the same issue on my 02 S60 2.4T. I've read on other forum's about the same issue with many other owners with the factory spec tires. I'm just been calling it a design flaw. I did see while changing oil yesterday where the tire is rubbing on the inner fender well, but its on a cover that might be able to be taken off or modified. I'm going to try to modify mine this weekend.
Old May 5, 2011 | 10:06 AM
RGT's Avatar
RGT
size will vary between different tires of the same size from different manufacturers, you can search the sizes on different sites and find ones that may clear....
Old May 5, 2011 | 10:13 AM
Mad Matt's Avatar
Chances are your Steering stops are warn and need to be replaced.
Another solution is to stop turning your steering wheel to full lock. You know when it's gonna rub so stop before then.
Old May 8, 2011 | 12:40 PM
coefamily's Avatar
dont turn the wheel that far soinds like a good soliton bit when your wife is driving the car......
Old May 9, 2011 | 06:12 PM
MYS6T's Avatar
Use 5 or so washer behind the steering stop.This does hinder the turning radius but by a small amount and it stops the Rub. GL
Conzo427
Jan 27, 2012 04:34 AM
Camden
Aug 6, 2010 12:42 PM
painthunter9
Nov 17, 2008 01:13 AM
AzNick
Nov 1, 2008 06:54 AM
JP
Jul 9, 2008 11:40 AM
