2001 Volvo S60 - Can't Turn Key in Ignition
Old Sep 7, 2011 | 05:38 PM
KSIMP88's Avatar
Default 2001 Volvo S60 - Can't Turn Key in Ignition
I can't turn my key. It won't go to position 1. What I have tried:
1. Jiggling the key
2. Re-inserting the key (multiple times
3. A little extra force
4. Flicking the shifter button (in case it was stuck)
5. Pressing brake
6. Pressing gas
7. Disconnecting and reconnecting negative battery cable
8. Tried other key
9. Get out of car, lock it, unlock, and try again (multiple tries)
10. Cussing at it
Any ideas? Is this locking tumblers or whatever?
Old Sep 7, 2011 | 06:16 PM
MYS6T's Avatar
Take a look at this older thread. It might help https://volvoforums.com/forum/volvo-...rs-lite-29676/
Old Sep 7, 2011 | 06:51 PM
KSIMP88's Avatar
Key won't turn INTO position 1.
Old Sep 7, 2011 | 08:15 PM
KSIMP88's Avatar
It's the tumblers.. There goes $380....
Old Dec 2, 2011 | 11:26 AM
tammygerner's Avatar
Arrow Wow it worked!
JUST HAD A CLIENT HAVE THE SAME PROBLEM AND I PUNCHED IN GOOGLE CANNOT TURN KEY TO VOLVO S60 AND I GOT THIS! WELL I GREASED THE KEY AND WIGGLED REAL HARD AND BAM...STARTED RIGHT UP! THANKS ALL!!!!!
Old Dec 3, 2011 | 03:32 PM
Nichals's Avatar
don't use grease!
grease collects dirt and dust and will eventually wear out your tumbler, if you already have don't do it again instead go to home depot and get some graphite powder this is designed to spray in key locks and it an excellent lubricant best of all it extends the life of your ignition! whereas grease will (in long term) do the opposite and can cause it to stick
Old Dec 8, 2011 | 07:22 AM
VolvoLover2011's Avatar
This scares me a little my SRS light has been on for some time and I can turn the key fine....IF I have the key in on a certain side...its strange. If I put it in the other way, it wont turn, but if I take the key out and flip it, it'll turn........
Once I couldnt get it to turn period and I was NOT going to force it, but my friend wiggled the steering wheel and I was able to turn it fine.
dodgerkcj
Jul 2, 2018 11:41 AM
ewgoforth
Jul 29, 2012 09:45 AM
spw2000
Jun 7, 2011 09:58 AM
lexusdave
Apr 21, 2009 07:56 PM
