2002 S60 early morning Coolant message
Old Oct 31, 2008 | 08:11 AM
ericsbaltimore's Avatar
Default 2002 S60 early morning Coolant message
Hi, there
I just bought a used 2002 S60. This morning is pretty cold,somewhere around 36 degrees. Just after I start the car, the message shows on " low coolant, check the engine". After fully heat up, the message goes away. I am wondering if I need to add some coolant to it. I read the manual and it states two kinds of coolant can not be mixed, I am not sure what was previously put in there. Should I just drain the coolant and put all new in there? Please advise. thanks a lot for your time and help.
Old Oct 31, 2008 | 08:24 AM
Default RE: 2002 S60 early morning Coolant message
You can top it up with a 50/50 green coolant mix. Or just add a slight bit of water to it.
Old Oct 31, 2008 | 08:29 AM
Thank you for the fast response. You are the best
Old Oct 31, 2008 | 08:32 AM
No problem glad I can be of help.
Old Nov 1, 2008 | 11:26 PM
one more question for you here, I just happen to find 1L concentrated coolantin my storage which is at least 4 years old. It was opened before but sealed after use. May I just add water using 50/50 to the Volvo? thanks
Old Nov 2, 2008 | 06:00 AM
That should be fine.
kriegtgod
Jan 8, 2013 09:16 PM
ssrob
May 26, 2011 07:00 AM
malaka
Aug 10, 2010 06:38 PM
snowmanpu
Feb 6, 2008 06:19 AM
axelm
Dec 2, 2007 02:08 PM
