2004 s60 Acceleration Issue
Old Jun 5, 2017 | 08:57 PM
William Sullivan's Avatar
Default 2004 s60 Acceleration Issue
I have an 2004 S60 AWD. It has various electrical issues... Radio changes channels by itself, driver side door window works occasionally, High beam indicator light works occasionally. Now I seem to be having a problem with acceleration. The car has no get up and go, it very slowly accelerates and its necessary for me to use the triptronic shifter to move through the gears. I have brought it to my local guy twice and he informed me that it was a blown fuse originally and now seems to be at a loss to fix the problem. Anyone else out there run into this problem? if yes, how did you fix it? Thanks for the help
Old Jun 6, 2017 | 09:13 AM
any idea which fuse was blown? that may give you a clue as to what the root cause was. I don't think the odd electrical problems are directly related but may point to a system voltage issue (weird happens when your system voltage goes below a threshold). Do you have a check engine light or other warnings? If so you should scan for fault codes including powertrain/transmission and chassis codes (not all budget scanners can see all codes). You may want to look at volvowiringdiagrams.com to see if you can find a diagram for your car - to see whether the CEM is in the service patch for various devices, inspect the battery terminals and big cables, do a simple voltage test of the battery and charging system. I'm wondering if you may be stuck in "limp mode".
jbyszewski
Mar 24, 2020 03:33 PM
huey3110
Dec 16, 2016 06:06 AM
volvorecycle
Jul 22, 2015 07:44 PM
Jjohns519
Aug 4, 2014 01:18 PM
Jojoloco
Dec 1, 2010 03:29 PM
