2005 S60 5T: Sounds like a Diesel in Idle
Old Mar 6, 2021 | 05:39 PM
Musepux's Avatar
Default 2005 S60 5T: Sounds like a Diesel in Idle
The Check Engine light of my 2005 S60 5T, 153k miles, came on. Two days later it sounded like a Diesel in Idle, after about 5 minutes. Diesel ticking/knocking disappears when RPM goes up.
Sound comes from the area marked in the attached photo.
Went to my repair shop and they found codes:
ECM-6140 -- Camshaft control exhaust -- Slow
ECM-611B -- Camshaft control, intake. Faulty
Repair shop says that some gears (?) the timing belt runs over are wearing out - I guess they refer to some tensioners etc?
Will bring it in to them for checking and estimate in a week.
Does this sound familiar to some? How big of a repair is that?
Thanks!
Old Apr 24, 2024 | 06:01 PM
chris761's Avatar
Did you find out what was wrong with it ?
Old Apr 24, 2024 | 07:07 PM
Musepux's Avatar
There were several things going on at that time.
The ticking noise was from oil sludge. Did an oil change with engine flush and all was good.
Old Apr 25, 2024 | 06:05 AM
chris761's Avatar
And the codes for the camshaft position sensor I have the same ones and thanks for the info
JD_xc90
Jan 29, 2015 04:18 PM
Muskoka
Aug 9, 2012 10:09 PM
SgtCheeseNOLS
Mar 22, 2011 06:56 PM
s60pilot
May 20, 2010 03:41 PM
crouchy
Mar 10, 2009 12:23 PM
