2007 S60 Stability Control Light Flashing
Old Oct 11, 2021 | 10:11 AM
onoah51's Avatar
Default 2007 S60 Stability Control Light Flashing
Howdy folks,
I recently replaced the right passenger side CV axle shaft on my S60. Ever since I replaced that part, the stability control light flashes on and off when driving. I went and got an alignment done thinking that would solve the problem, however it did not. The flashing occurs after the car is started and continues for a few minutes before going away at which point the speed limiting disappears. When the CV axle shaft was replaced, there was a lot of grease from it leaking and I cleaned it off with some brake cleaner. I'm thinking the brake cleaner might have affected the sensors down in the wheel well, but honestly, I'm not sure.
I'm looking for some help as to what this might be, as I haven't been to find any information regarding this issue.
Thanks!
Old Oct 13, 2021 | 10:21 AM
Dingus's Avatar
Check the wheel speed sensor
spiffy926
Jan 3, 2021 03:09 PM
Vol1
Jan 3, 2017 08:42 AM
L76
Aug 25, 2016 09:16 PM
Arch Stanton
Jan 8, 2014 09:15 AM
ryan319
Nov 18, 2009 09:34 AM
